TOPIC: [SOLVED] top-x Module Position Backgrounds
top-x Module Position Backgrounds 8 months 1 week ago #1
  • dlong
  • dlong's Avatar
Running Maximum template version 1.0.001, I am trying to change the backgrounds on the "top-x" module positions, but they cannot be changed. As an example, the top-d position has a gradient blue background, although the admin interface showed a blank textbox for the image name. When I change the image file in the admin, the original blue gradient background stays in place, while the new file name does show in the file textbox. If I try to add a new image to position top-c which had never been used, the image will not show. In the case of top-a, the listed filename is not the one which appears in the rendered browser. I've tried to clear the cache, etc. How do I get the template repaired or updated, since my window of support has expired?
top-x Module Position Backgrounds 8 months 1 week ago #2
At first, please delete all layouts you dont needed
www.joomlaplates.com/support/documentation/warp-7-layouts
Live Url please...
[SOLVED] top-x Module Position Backgrounds 8 months 1 week ago #3
  • dlong
  • dlong's Avatar
top-x Module Position Backgrounds 8 months 1 week ago #4
  • dlong
  • dlong's Avatar
Thanks, JP. That was the issue, looking at the default layout rather than the one I am using. I had forgotten to change the dropdown.
