TOPIC: [SOLVED] Maximum template customising not work
Maximum template customising not work 6 months 5 days ago #1
  • brutar
  • brutar's Avatar
I have problem with the teplate MAXIMUM. When I setup in the setting, that I want to have small-header and save it, the change is not aplied in the real. Same is with the colorors.
How can I solve my problem?
www.mobilenergie.cz/!new
Thank you.
Best regards
Ondrej Fila
Maximum template customising not work 6 months 5 days ago #2
please delete all layouts you dont need
Maximum template customising not work 6 months 4 days ago #3
  • brutar
  • brutar's Avatar
I deleted the layouts and its working now.
I have one more question, how can I put the map before the footer? I mean, that I want to see the map in same setting but on the top of the footer?
Thank you.
Maximum template customising not work 6 months 4 days ago #4
Thats working only if you edit the layouts/theme.php and move the DIV map above the footer
Maximum template customising not work 6 months 3 days ago #5
  • brutar
  • brutar's Avatar
Ok its clear.
And I hope last question on the below link I have one article. The article is align to the left site. How can center the article?
www.mobilenergie.cz/!new/index.php/elektrocentraly/qas100-1
Thank you.
Maximum template customising not work 6 months 3 days ago #6
Only possible with the Joomla content editor > text-align:center
Maximum template customising not work 6 months 3 days ago #7
  • brutar
  • brutar's Avatar
I used the editor and align center, but only text was align to the center.
I think, that you did not understand me well. I mean, that the article is on the left site see the printscreen and for example by the template ultimate is article center see the printscreen in attachment.
I need to have articles in the center.
Maximum template customising not work 6 months 2 days ago #8
Our article shown in demo is align left but the image is full width!
Maximum template customising not work 5 months 3 days ago #9
  • brutar
  • brutar's Avatar
I would like to ask you for your help. In customising I setup backround see the attachment, but in two section on my webpages is load other backround and I dont know why?
When can I setup same backround also for this two section?
Thank you
Maximum template customising not work 5 months 3 days ago #10
  • brutar
  • brutar's Avatar
I solved problem by myself. I recreated menu items and now is all ok.
[SOLVED] Maximum template customising not work 5 months 2 days ago #11
