TOPIC: [SOLVED] Hyperlink Color
Hyperlink Color 4 years 9 months ago #1
  • vtobi
  • vtobi's Avatar
How can the hyperlink color be changed? I currently use the blue style. The gray color with a hyperlink should also be changed to dark blue.
Hyperlink Color 4 years 9 months ago #2
Yes everything can be changed but you need some CSS knowhow.
Add the code below to your file > css / color / blue.css ( if blue is selected from the backend)
a {color:#FF0000}
a:hover {#CCC}
Hyperlink Color 4 years 9 months ago #3
  • vtobi
  • vtobi's Avatar
The problem was done with the assistance. Thank you!
[SOLVED] Hyperlink Color 4 years 9 months ago #4
