TOPIC: [SOLVED] change dotnav color possible
change dotnav color possible 3 years 4 months ago #1
  • Rossen
  • Rossen's Avatar
i've followed the dotnav instructions for an menu with dots.
The dots are grey/white but so is my website.
I would like te have the dots in blue.
Is this possible?
change dotnav color possible 3 years 4 months ago #2
yes you can change the color. Add this code to your css/custom.css and modify the color code:
.uk-dotnav > * > * {
background: rgba(50, 50, 50, 0.1);
The following user(s) said Thank You: Rossen
[SOLVED] change dotnav color possible 3 years 4 months ago #3
  • Rossen
  • Rossen's Avatar
