TOPIC: [SOLVED] Mobile menu style
Mobile menu style 1 year 2 months ago #1
  • hoga
  • hoga's Avatar
I'm currently working on the basis of the Musician template to create a new page (www.hogawebdesign.de/has2019).
The mobile menu lists all the menu items among each other. Since the site will be very extensive, I would like there the Accordion style, as it is in the newer templates apparently standard.
Can I also have this in the Musician template - and if so, what do I have to change?
Template: musician, Joomla 3.9.3
Thank you for the hopefully help.
Mobile menu style 1 year 2 months ago #2
here is an instruction how you can do it
yootheme.com/support/question/88179?order=modified
Mobile menu style 1 year 2 months ago #3
  • hoga
  • hoga's Avatar
Vielen Dank, es hat geklappt!!
[SOLVED] Mobile menu style 1 year 2 months ago #4
  • hoga
  • hoga's Avatar
