TOPIC: [SOLVED] Installation Joomla + Sample data
Installation Joomla + Sample data 7 months 2 weeks ago #1
  • vw360
  • vw360's Avatar
After download the package JP-Musician, i just installed joomla but i do not seethe last installation step where press the Install Sample Data button
What to do ?
Thanks for your help,
RM
Installation Joomla + Sample data 7 months 2 weeks ago #2
the quickstart package is still a Joomla 3.8.1 version and its not working with PHP 7,x.
We are updating our quickstart packages just in time, but it takes a while.
Therefore please switch back to PHP 5.6 and install the quickstart package and then you can update the Joomla and switch back to PHP 7.x
The following user(s) said Thank You: vw360
[SOLVED] Installation Joomla + Sample data 7 months 1 week ago #3
  • vw360
  • vw360's Avatar
