TOPIC: Dropdown menu second level
Dropdown menu second level 4 years 3 months ago #1
  • Thandie
  • Thandie's Avatar
Hi!
In my main menu I have, by levels:
Item A
»Item B
»»Item C
Item C appears as list of Item B, but the client wants it as a drop menu.
How can I make this possible please?
Thanks!
Dropdown menu second level 4 years 3 months ago #2
Live url please and a screenshot what do you mean exactly
Dropdown menu second level 4 years 3 months ago #3
  • Thandie
  • Thandie's Avatar
Hi!
The link is: www.stj-gb.gw/ (I've put it online for your viewing purposes).
Screenshot is attached in the image bellow.
If you need any other information, I will gladly provide.
Thanks!
Dropdown menu second level 4 years 3 months ago #4
1.) There is no image attached
2.) I cant see any problems of the menu ( main menu allows only 1 sublevel)
3.) Please add a detail link where is the problem and not only the URL
Dropdown menu second level 4 years 3 months ago #5
  • Thandie
  • Thandie's Avatar
Im sorry for this confusion, the image was in png and not jpeg. I think it can be viewed now. Thanks!
or s11.postimg.org/3zbfpw9rn/dropdown_menu_example.jpg
Dropdown menu second level 4 years 3 months ago #6
Sorry thats not possible.
And it depends on the mobile ( tablet, touch screen) verification.
This template support only a second level but no third level menu item.
Dropdown menu second level 4 years 3 months ago #7
  • Thandie
  • Thandie's Avatar
Thank you for your reply.
Unfortunately the client keeps insisting on this matter. I tried to install a menu extension, and enable it in the menu module area but it stays as shown in the page stj-gb.gw/
It opens vertically, not horizontally. Is the template also not built to work with a different menu, or can I change it?
Thanks once again
Dropdown menu second level 4 years 3 months ago #8
Please ask the menu developer please.
Because I dont know this menu extension
