TOPIC: Multi-columns sub menus
Multi-columns sub menus 1 year 4 months ago #1
  • Atomos
  • Atomos's Avatar
Hi!
I am new on Joomla! and I have purchased Perfect template.
I would like to create sub-menus with two columns, but I can't find the way to set-up multiple columns sub menus.
Could you help me please?
Multi-columns sub menus 1 year 4 months ago #2
Template Settings > Menu > Columns
The following user(s) said Thank You: Atomos
Multi-columns sub menus 7 months 3 weeks ago #3
  • spottedhaggis
  • spottedhaggis's Avatar
I would like to make use of Megamenu and have installed DJMegamenu but when I place it in the menu position, it does not display correctly, but if I place it in topA, or Bottom A, etc it displays correctly.
Can you advise what I need to adjust in the menu location to enable this addon to work please.
Multi-columns sub menus 7 months 2 weeks ago #4
sorry the DJMegamenu on our menu position is not supported
Multi-columns sub menus 7 months 2 weeks ago #5
  • spottedhaggis
Are any megamenus supported? dissapointing..
Multi-columns sub menus 7 months 2 weeks ago #6
All megamenu modules are supported, but not on module position "menu"
