TOPIC: [SOLVED] sticky navigation
sticky navigation 6 months 1 week ago #1
  • mhp
  • mhp's Avatar
Hello
How can I have the navigation always sticky fixed without animation fade out and fade in after scrolling?
sticky navigation 6 months 1 week ago #2
  • cg
  • cg's Avatar
Hi mhp,
I think the attached picture will help you.
sticky navigation 6 months 1 week ago #3
  • mhp
  • mhp's Avatar
unfortunately not. This is marked, but as well with the sticky navigation after scrolling down the navigation fades out for a moment and then fades in again. I want to overreide that so the navigation is allways displayed.
sticky navigation 6 months 1 week ago #4
  • cg
  • cg's Avatar
I'm not that familiar with the Customizer, but I guess this is a problem with the assignment of the layouts.
If you post a link, then I can give you the CSS code.
For the time being, I usually prefer this dirty and fast solution
sticky navigation 6 months 1 week ago #5
  • mhp
  • mhp's Avatar
Here you are:
Secret text
sticky navigation 6 months 1 week ago #6
  • cg
  • cg's Avatar
I'm a customer like you without permission to read your hidden code.
Joomlaplates will shurely know a solution.
sticky navigation 6 months 1 week ago #7
  • mhp
  • mhp's Avatar
ah ok, take the demo, it is the same effect. the first 200px you scroll, the navigation disappears.
demo.joomlaplates.com/jp_perfect/
sticky navigation 6 months 1 week ago #8
  • cg
  • cg's Avatar
Here the Code:
/** with top-toolbar  */
.toolbar-outer.uk-clearfix {
    position: fixed;
    z-index: 1000;
nav.tm-navbar.uk-navbar {
    position: fixed;
    top: 30px;
    width: 100%;
    z-index: 1000;
/** Without top-toolbar:*/
    display: none;
   position: fixed;
   z-index: 1000;
   top: 0;
sticky navigation 6 months 1 week ago #9
  • mhp
  • mhp's Avatar
thanks but with that code the navi is overlaying the other modules even without scrolling.
sticky navigation 6 months 1 week ago #10
  • cg
  • cg's Avatar
sprocket-features.layout-slideshow {
    margin-top: 100px;
sticky navigation 6 months 1 week ago #11
You have to edit the file:
...\templates\jp-perfect\layouts\theme.php
Before:
After:
The following user(s) said Thank You: mhp, cg
[SOLVED] sticky navigation 6 months 1 week ago #12
  • mhp
  • mhp's Avatar
