TOPIC: space or padding between module positions
space or padding between module positions 1 year 1 month ago #1
  • adavidino@hotmail.com
  • adavidino@hotmail.com's Avatar
Hi
Is it possible to reduce the space between the modules positions? I mean in the desktop view the space between the modules is too much, I would like to have them more close to each other.
Is there a class that i can modify in my custom.css?
Thank you in advance for your support
space or padding between module positions 1 year 1 month ago #2
you can setup the space in customizer
>> Custiomizer > Advanced > Grid
space or padding between module positions 1 year 3 weeks ago #3
  • shivalee
  • shivalee's Avatar
I am also having the same problem with large vertical gaps between top-a top-b modules. I have taken a look at the Customizer Grid, and most of the variables are not editable type '@'. I have fiddled with the others and they don't change anything.
If I look at the code in the browser, I think the main culprit is of the type … <div class="bottom-a-outer uk-cover-background" id="bottom-a" style="padding:100px 0"> But my attempts to override this in custom.css have no effect. (ie. <div class="bottom-a-outer uk-cover-background" id="bottom-a" style="padding-top: 50px; padding-bottom: 50px; ">)
I can change the values in the browser, but cant find how to make permanent changes.
Basically I'd like to close up the modules to around 50px.
Thanks for your help...
space or padding between module positions 1 year 3 weeks ago #4
The perfect theme has not the code included.
Which theme do you mean?
space or padding between module positions 1 year 3 weeks ago #5
  • shivalee
  • shivalee's Avatar
Sorry, I didn't realise this thread is Template-specific!
I am having the large-padding problem working with the SENSATION template.
:) Lee
space or padding between module positions 1 year 3 weeks ago #6
In Sensation you can setup the space in Template settings > Backgrounds
space or padding between module positions 1 year 1 week ago #7
  • shivalee
  • shivalee's Avatar
Thank You! That works. Very well designed template dashboard!
