TOPIC: Problems Slider
Problems Slider 7 years 1 month ago #1
  • TejidoDigital
  • TejidoDigital's Avatar
hello,
I installed the template and the slider is not working, only shows an image and the other images do not load.
Thank you.
Problems Slider 7 years 1 month ago #2
  • TejidoDigital
Send by mail my problem with as many possible directions and in less than 24 hours solved my problem.
Thank you very much, great answer.
Problems Slider 7 years 1 month ago #3
Thanks for info.
The problem was: The second slide was not enabled.
