TOPIC: Console errors and warnings
Console errors and warnings 6 years 11 months ago #1
  • skrzypol
  • skrzypol's Avatar
Hello!
I have purchased a single-template licence for the JM-Personal. During the configuration I have encountered following errors and warnings in the firebug console (see attached picture). I suppose it is connected with the facebook button which is not displayed at all despite enabling it on in the template configuration.
Attachment firebug.jpg not found
Please help to resolve this problem.
Best Regards
Piotr Skrzypczyk
Console errors and warnings 6 years 11 months ago #2
Please disable the FB button and try again?
And live Url would be helpful!
Console errors and warnings 6 years 11 months ago #3
  • skrzypol
  • skrzypol's Avatar
Yep, disabling FB button removes errors and warnings like it was supposed.
Problem occurs at www.podoestetik.pl but the website is offline - where should I pass you credentials?
Another bug is when I try to turn on compression (combination and minify only) - whole template crashes no matter what browser used.
Console errors and warnings 6 years 11 months ago #4
Does your server support GZIP compression, if not, then this will not work.
Otherwise goto the css folder and delete the "global.css" coz you dont need it!
