TOPIC: Reduce margin and pading
Reduce margin and pading 6 years 2 days ago #1
  • keralahaus
  • keralahaus's Avatar
Hallo, as u told yesterday i removed h3. it worked. but my issue with Margin and Padding is not solved. After changing with Custom.css, it slips again as earlier.
my seite: www.keralahaus.com
Thank u in advance.
jp-creative Template
Reduce margin and pading 6 years 2 days ago #2
You can change the gap ( margin / padding) if you add this code to your file:
>> css / custom.css
.headerbar {margin-bottom:0;padding-bottom:0}
Reduce margin and pading 6 years 2 days ago #3
  • keralahaus
now working. solved. Thank u very much
Reduce margin and pading 6 years 2 days ago #4
  • keralahaus
