TOPIC: white screen after install JP-pure
white screen after install JP-pure 3 years 6 months ago #1
  • Polleke
  • Polleke's Avatar
after installing JP-Pure on my (test) system. I got a white screen on loocking at the frontend.
i have
php 7
joomla 3.6.4
databse 5.6.29
can you please help me.
regards Jan
white screen after install JP-pure 3 years 6 months ago #2
White Screen is a PHP error.
Please setup the error message reporting level to >> maximum ( Joomla Configuration )
Now you will see an error message instead of a white screen.
1.) Whats your test system? Xampp or Mac system or online server??
2.) What did you installed? Quickstart or the Template only?
white screen after install JP-pure 3 years 6 months ago #3
  • Polleke
  • Polleke's Avatar
Hi
i set debug to on and level to maximum,
but still a white screen, no errors.
The test system, is a subdomain of my website. So linux and apache.
I created the testsystem by using akeeba backup and restore it in a sub domain.
I do not know what is used. i think i installed a template because o do not know what quickstart is.
I unzipped the unzip_me_first and then installed the zip file i found in the template.
i tryed JP_Group, that seems to work, but i realy want jp-pure
white screen after install JP-pure 3 years 6 months ago #4
the Pure theme is working with PHP 7.
Please use the quickstart package and not any Akeeba backup files... I think akeeba is the problem..
How to use our quickstart package:
www.joomlaplates.com/support/documentation/install-demo-content
white screen after install JP-pure 3 years 5 months ago #5
  • Polleke
  • Polleke's Avatar
hi,
i have php 7
If i use quickstart do i loose any articles, photos, components etc ?
regards Jan
white screen after install JP-pure 3 years 5 months ago #6
No you do not lose anything!!
If any Joomla extension is not working you can switch back to PHP 5.6
