TOPIC: Link Class does not work, smoothscroller scrolls t
Link Class does not work, smoothscroller scrolls t 2 years 1 week ago #1
  • jhmakes
  • jhmakes's Avatar
I'm really happy with your template, but two issues kept me struggeling for quite a while now, perhaps you have an idea to solve them.
1. I'd like to make two menu items appear in a different color. So I tried to use "Link Class" and added the corresponding entries to the css. Unfortunately the links do not have a unique id and the link class I used in the backend is not shown in the sourcecode of the page when viewed with Chrome developer tools. Obviously the color of the links does not change. Do you have any hint for that?
2. I'm using your template as a one-pager, so I'm making use of the smoothscroll-ability, which works fine. My problem is, that it does scroll too far, so that for example the headline of the section I'm scrolling to is hidden behind the headerbar. Is there a possibility to tell the scroller to scroll 150px or so less? If so, could this be set seperately for every menu item?
Thank you very much!
Kind regards,
Jan
The following user(s) said Thank You: Sjouke Bouius
