TOPIC: Trouble with Gcalendar
Trouble with Gcalendar 8 years 3 months ago #1
  • john66
  • john66's Avatar
I have some trouble when I try to use Gcalendar with JP-Restaurant.
Can\'t get display of the calendar.
It seems to be a template isue as I have no problem with other template.
Someone can help me ?
Thaks in advance and best regards,
John
Re:Trouble with Gcalendar 8 years 3 months ago #2
  • Joomlaplates
  • Joomlaplates's Avatar
Live URL please and URL of the Gcalender.
Joomlaplates.com cannot guarantee the templates will function with all 3rd party components as there is currently no certification process for such components.
Re:Trouble with Gcalendar 8 years 3 months ago #3
  • john66
  • john66's Avatar
Thank for your answer.
I fully agree that you can\'t certified templates for all 3rd party products. I just post this to inform potential customer.
I found the answer on an other site relating some \"freewheel\" trouble with Gcalendar.
This is due to \"conflict\" in Jquery between Gcalendar and Superfish menu.
The following fix do the job for me :
In index.php located in the JP template folder, just move lines concerning Jquery and put them just after <head>
like this :
<!-- LOADING JQUERY FUNCTIONS -->
<?php if ($jquery == \"1\") : ?>
<link rel=\"stylesheet\" type=\"text/css\" href=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/superfish/css/superfish.css\" media=\"screen\" />
<link href=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template ?>/slimbox/css/slimbox2.css\" rel=\"stylesheet\"  type=\"text/css\" />
<script type=\"text/javascript\" src=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/superfish/js/jquery.js\"></script>
<script type=\"text/javascript\" src=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/superfish/js/hoverIntent.js\"></script>
<script type=\"text/javascript\" src=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/superfish/js/supersubs.js\"></script>
<script type=\"text/javascript\" src=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/superfish/js/superfish.js\"></script>
<script type=\"text/javascript\" src=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/superfish/js/jquery.easing.min.js\"></script>
<script type=\"text/javascript\" src=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/superfish/js/jquery-color-fade.js\"></script>
<script src=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/js/tooltip.js\" type=\"text/javascript\"></script>
<script src=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template?>/slimbox/js/slimbox2.js\" type=\"text/javascript\"></script>
<script type=\"text/javascript\">
jQuery.noConflict();
jQuery(function($){
        $(\"ul.sf-menu\")
                .supersubs({minWidth:16, maxWidth:45, extraWidth:1})
                .superfish({
                        delay:       100,                            // one second delay on mouseout
            animation:   {opacity:\'show\',height:\'show\'},  // fade-in and slide-down animation
            speed:       \'fast\',                          // faster animation speed
            autoArrows:  true,                           // disable generation of arrow mark-up
            dropShadows: true                            // disable drop shadows
        $(\".tooltip\").simpletooltip();
</script>
<?php endif; ?>
<?php if ($jquery == \"0\") : ?>
<link href=\"<?php echo $this->baseurl; ?>/templates/<?php echo $this->template ?>/css/suckerfish.css\" rel=\"stylesheet\"  type=\"text/css\" />
<?php endif; ?>
<jdoc:include type=\"head\" />
Hope this can help someone !
Regards,
John
