TOPIC: Sidebar when set to Scroll has issues with height
Sidebar when set to Scroll has issues with height 6 years 2 months ago #1
  • Roym
  • Roym's Avatar
I have set the sidebar-l to scroll, but if I add more than two modules into the sidebar (two into logo position and two into social position) it does not match height properly with jp-right.
Update: I believe it is in the template.js calculation of height to match the left sidebar to document height, and likely one of the modules is loading after the calculation. Not sure how to fix it, but have seen it mentioned on other websites using the warp framework.
Sidebar when set to Scroll has issues with height 6 years 2 months ago #2
The sidebar-l is basically not suitable for more then 2 modules. ( logo & social).
And yes youre right its a calculation problem of the WARP framework.
