TOPIC: RokSprocket v2.1.21 - Mosaic - alt-tags
RokSprocket v2.1.21 - Mosaic - alt-tags 3 years 5 months ago #1
  • andweb
  • andweb's Avatar
I use the template snowflake and the extension RokSprocket, Mosaic. I have unfortunately a problem with the alt-tags.
The images are taken from the corresponding article (introduction picture), where the alternative text was specified.
The override (<?php echo $item->getPrimaryImage()->getAlttext(); ?>) I have adapted:
/templates/corporategames/roksprocket/layouts/mosaic/default/item.php
<?php if ($item->getPrimaryLink()) : ?><a href="<?php echo $item->getPrimaryLink()->getUrl(); ?>"><?php endif; ?>
				<img src="<?php echo $item->getPrimaryImage()->getSource(); ?>" alt="<?php echo $item->getPrimaryImage()->getAlttext(); ?>" class="sprocket-mosaic-image" />
					<span class="sprocket-mosaic-hover"></span>
					<span class="sprocket-mosaic-shadow"></span>
					<?php if ($item->getPrimaryLink()) : ?>	<span class="sprocket-mosaic-hovercontent"><span>&nbsp;</span></span> <?php endif; ?>
				</a>
				<?php endif; ?>
			</div>
			<?php else : ?>
				<?php if ($item->getPrimaryImage()) :?>
				<div class="sprocket-mosaic-image-container">
					</a>
					<?php endif; ?>
				</div>
				<?php endif; ?>
However, the alternative text of the article image is not displayed in the source code: http://www.corporate-games.de
What am I doing wrong? :)
Thx in advance
Uli
RokSprocket v2.1.21 - Mosaic - alt-tags 3 years 5 months ago #2
Hi Uli,
please update the roksprocket and then use the following code for the "alt" parameter:
alt="<?php echo $item->getPrimaryImage ()->getAlttext(); ?>"
RokSprocket v2.1.21 - Mosaic - alt-tags 3 years 5 months ago #3
  • andweb
  • andweb's Avatar
I am a bit confused :)
I already use the current version (RokSprocket v2.1.21) and the code is already included.
RokSprocket v2.1.21 - Mosaic - alt-tags 3 years 5 months ago #4
1.) Clean your Joomla and Browser cache
2.) Insert an alt tag for the Content image > image 1
3.) Check the source code > image 2
RokSprocket v2.1.21 - Mosaic - alt-tags 3 years 5 months ago #5
  • andweb
  • andweb's Avatar
Hi again,
Unfortunately, all this has brought no success.
Uli
RokSprocket v2.1.21 - Mosaic - alt-tags 3 years 5 months ago #6
Maybe you are in the wrong file.
Please check it, because there are 2 different styles > gallery and default.
and
/templates/corporategames/roksprocket/layouts/mosaic/gallery/item.php
The following user(s) said Thank You: andweb
RokSprocket v2.1.21 - Mosaic - alt-tags 3 years 5 months ago #7
  • andweb
  • andweb's Avatar
Thank you for your support!
Your note to another file has brought me to the solution.
The override for the style "default" was created (The override "Gallery" does not exist with me.), but changes to the item.php have not caused anything. For this the direct changes in the "components/com_roksprocket/ ..." directory worked. Funny.
Many many thanks.
Uli
