TOPIC: [SOLVED] Rokcommon / Rok Sproket
Rokcommon / Rok Sproket 1 year 8 months ago #1
  • richardstehle
  • richardstehle's Avatar
I need to update RokSprocket Module from 2.1.23 to 2.1.25
I downloaded wp_rokcommon-3.2.6.zip alreday.
With the extensions/install utility with joomla 3.9 i can not uüdate this module.
Warnung
JInstaller: :Install: Die Joomla!-XML-Installationsdatei konnte nicht gefunden werden.
Fehler
Es kann kein Installationspaket gefunden werden!
What can i do??
best regards
Richard
Rokcommon / Rok Sproket 1 year 8 months ago #2
wp_rokcommon-3.2.6.zip is for Wordpress!
www.joomlaplates.com/forum/important-mes...cket-update-problems
Rokcommon / Rok Sproket 1 year 8 months ago #3
  • richardstehle
OK, i did so.
Now i Get an error message on one page:
Warning: count(): Parameter must be an array or an object that implements Countable in C:\xampp7.2\apps\joomla\htdocs\templates\promark\roksprocket\layouts\mosaic\themes\default\index.php on line 19
Whats wrong here?
Thanks for your assistance.
Best regards
Richard
Rokcommon / Rok Sproket 1 year 8 months ago #4
this is not one of our theme > Promark
Rokcommon / Rok Sproket 1 year 8 months ago #5
  • richardstehle
I copied the SOUNDS Template to "promark" before i made modifications (colours etc.)
Rokcommon / Rok Sproket 1 year 8 months ago #6
Please use the org theme name otherwise you are getting problems with the folders.
Rokcommon / Rok Sproket 1 year 8 months ago #7
  • richardstehle
I just generated the module new, and now it works. Even with the old template and PHP 7.2
[SOLVED] Rokcommon / Rok Sproket 1 year 8 months ago #8
