TOPIC: Prevent JT skitter module from reload
Prevent JT skitter module from reload 6 years 2 months ago #1
  • MK2009
  • MK2009's Avatar
Hi again,
do you know an easy method to prevent the jt skitter module from restarting everytime, when changing another item from the main menue? Basically I would like the JT Skitter module continuing the slideshow while the joomla content is changing. Currently the JT Skitter restarts at picture 1 everytime I select a new menue item...
Regards, Martin
Prevent JT skitter module from reload 6 years 2 months ago #2
Hi Martin,
sorry thats not possible, because if youre clicking the menu the page is reloading too.
Therefore the slideshow have to load the images too.
Prevent JT skitter module from reload 6 years 2 months ago #3
  • MK2009
  • MK2009's Avatar
thanks for the infromation. Does this apply for submenues, too? I mean, is there a possible configuartion to create a workaround, so that e.g. only the innercontent.php include is executed?
Sorry for beeing this peculiar, however, but I think this could change site impression to a valuable extent. The live site: www.developingnetworks.com
Martin
Prevent JT skitter module from reload 6 years 2 months ago #4
  • MK2009
  • MK2009's Avatar
Hi again,
just for my information, is it possible to get support from you in the means of some small business in general?
I found another thing, which basically should be minor, I would like to add on the template, but, although I know about what I do a little, it is quite hard and time consuming for me as I am not a true professional.
You can write to me directly by info*at*developingnetworks.de if you prefer.
Regards, Martin
