TOPIC: [SOLVED] JP-SPA Template position Bottom25-1 not showing
JP-SPA Template position Bottom25-1 not showing 4 years 3 months ago #1
  • brentmin
  • brentmin's Avatar
According to the template module positions there are four positions under Bottom33-1, Bottom33-2, Bottom33-3 labelled Bottom25-1, Bottom-25-2, Bottom25-3, Bottom25-4. However even with the Bottom25 positions published in the module manager it does not show at all on the front-end of the site. In the template manager the bottomgrid are switched on
JP-SPA Template position Bottom25-1 not showing 4 years 3 months ago #2
Live url and if possible admin access to your Joomla site.
Send the data to: support@joomlaplates.com
JP-SPA Template position Bottom25-1 not showing 4 years 3 months ago #3
  • brentmin
  • brentmin's Avatar
Will do shortyl
[SOLVED] JP-SPA Template position Bottom25-1 not showing 4 years 3 months ago #4
