TOPIC: JA-Spa and bootstrap
JA-Spa and bootstrap 2 years 9 months ago #1
  • Arkomat
  • Arkomat's Avatar
I have a question about the JA-Spa template.
I'm trying to create an override in Joomla 3.x and want to use bootstrap for the creation of the HTML in the override page.
Although I used the correct bootstrap code in the HTML the code is not working properly. The questions are as follows:
  • Is bootstrap loaded with the template
  • If loaded with the template which version of Bootstrap is loaded
  • If not loaded automatically where can I secure the loading of the bootstrap code
Thank you
Arkomat
JA-Spa and bootstrap 2 years 9 months ago #2
the Spa template is not loading any bootsrap files.
All bootstrap files are loaded by Joomla system > Site > right click > show source
Now you can see all css files which are loaded.
