TOPIC: [SOLVED] Underline disappears after copying a module
Underline disappears after copying a module 8 months 2 weeks ago #1
  • erlautomation
  • erlautomation's Avatar
I used the contact module from the sample data to make an own contact. That works perfectly.
As soon as the module is copied the underline disappears. What went wrong or how can I fix that?
beta.erl-gmbh.de/index.php/service/verschleissteile
Underline disappears after copying a module 8 months 2 weeks ago #2
Setup the copied module to the same style / class like the other module
www.joomlaplates.com/support/documentation/warp-7-modules
The following user(s) said Thank You: erlautomation
[SOLVED] Underline disappears after copying a module 8 months 2 weeks ago #3
  • erlautomation
