TOPIC: Applying Module Class Suffix
Applying Module Class Suffix 3 years 9 months ago #1
  • VishalL
  • VishalL's Avatar
Hi. Is there a way to apply the Box Grey style to the system output and main menu?
When I add the "Box Grey" style to the to the menu via: EXTENSIONS->MODULES->MAIN MENU->ADVANCED->MODULE CLASS SUFFIX it fails to apply the style with the menu staying black.
Also, how do I add the Box Grey style to the main system output?
Applying Module Class Suffix 3 years 9 months ago #2
1.) The menu module color must be changed at Cutomizer and not with module class suffix.
>> Template options > Customizer > Advanced Mode > Panel > Primary Box
>> After that you can assign the "primary Box" to the module in Template options > Module
www.joomlaplates.com/support/documentati...the-customizer-warp7
2.) The system output must be changed in css code > css/custom.css
The following user(s) said Thank You: VishalL
Applying Module Class Suffix 3 years 9 months ago #3
  • VishalL
  • VishalL's Avatar
Thanks.
Concerning the Menu style. I have this template set as a secondary template only to be applied to the websites store pages. When I try customize it I get the message that customization is not available for this template. Is this due to it not being the default style? (If I switch it back to the default style it allows customization as normal - Is this normal Warp7 behavior?)
Applying Module Class Suffix 3 years 9 months ago #4
you can not duplicate our theme within Joomla.
If you want to have different styles for different menu item you have to do this with "layouts"
How it works:
www.joomlaplates.com/support/documentati...profile-to-menu-item
