TOPIC: Change Color for Links dont work
Change Color for Links dont work 3 years 7 months ago #1
  • Nilsen
  • Nilsen's Avatar
Hello
My Homepage had a Menu for change Color (for the visitors).
Look at the Page on the menu "Deine Farbe" on Website knipsografen.ch.tiberius.sui-inter.net/
All Color-Change-Items work perfectly.
But the "Gelb"-Changer had Problems. I only wont change the background on the Menu and the link-color.
Look at the Attachment.
Correct:
Incorrect:
I had make a copy of the default Color in the Customizer an set the "Link Color and Primary Background.
Thank you for your help.
Change Color for Links dont work 3 years 7 months ago #2
please duplicate your wanted style within customizer.
After that you can change what you need.
To change the orange color, please select all "orange" color fields to your won one.
See image attached.
Change Color for Links dont work 3 years 7 months ago #3
  • Nilsen
  • Nilsen's Avatar
Hello
Thanks for your qiuck answer. But you read my text not so good :-(
I had make a copy of the default Style and chanche the value.
I can change the Menu-background color without problems.
But the link-color dont change - they had the same color like the default styxle.
All other styles that i change - word perfrectly
Pleas look at the Attachment
Thank you very much.
Change Color for Links dont work 3 years 7 months ago #4
if you could not find the link color in customizer, add the css code manually into the css/custom.css
a, .uk-link {
color: #de6e02;
Change Color for Links dont work 3 years 7 months ago #5
  • Nilsen
  • Nilsen's Avatar
Thank you for the Answer.
When I set the link color on the CSS File - all links change to the neue color (yellow).
But i want only change the link color of the style yellow (/?style=yellow)
The visitor should have the choise of 5 color-sets with different colors of links, menu-background and other buttons.
Do you have a CSS-Code to change only the link color of the Style /?style=yellow
Change Color for Links dont work 3 years 7 months ago #6
You can add the "custom.css" to your folder:
>> styles/yellow/css/custom.css
too
The following user(s) said Thank You: Nilsen
[SOLVED] Change Color for Links dont work 3 years 7 months ago #7
  • Nilsen
  • Nilsen's Avatar
