jp_maximum - nothing's working, why?
I'm trying to work with maximum template but nothing seems to work...
For instance:
in the layout section of template I set up position top-B as "stacked" but when I publish a second module in this position it is not stacked, it's still parallel. (this is current state on the page)
So I put the module in the position top-c - it's ok but when I go to template settings end set it up tu "full width" and section padding i.e 2% 2% 2% 2% - it's not working at all, the module is still in boxed mode and padding settings are not working?
I mean what gives?
Where is te problem? First time I have this kind of problems with a template... Please help because id drives me crazy!
Live url; dalin.atthost24.pl
Regards
Lukasz
For instance:
I mean what gives?
Regards
Lukasz
by lukaszw80
- Thank you received: 1713
Replied by joomlaplates on topic jp_maximum - nothing's working, why?
Posted 2 years 11 months ago #29152
please check the layout settings.
Maybe a layout is assinged to a menu item
www.joomlaplates.com/template-documentation/warp-7-layouts
