[SOLVED] Menu on small window
- davidanna23
- Thank you received: 2
Hello, on my website:
www.residencealparadiso.it
, when the width of the Desktop window is less than 1063px (in small laptops), the menu is bad: Text at the top, out of the gray bar.
How do I set that when the window width is less than 1063px, the mobile menu (hamburger menu) appears?
by davidanna23
- Thank you received: 1713
Setup the breakpoints > forum search
- davidanna23
If I make the change from Customizer, it goes crazy all the template, that I had modified in the code css.
Can I change the values of breakpoints in the theme.css file?
Thanks for help me.
Thanks for help me.
by davidanna23
No, please dont edit the theme.css it will be overwritten by compimling
- davidanna23
I’ve already changed it.
Is there no way to edit Breakpoints from theme.css?
Thanks
Thanks
Last Edit:3 years 3 months ago
by davidanna23
Last edit: 3 years 3 months ago by davidanna23.
breakpoints must be changed in customizer.
Or you can copy and paste the code from theme.css to custom.css
