[SOLVED] Modules error: operator not supported for strings
- v.garofalo
Modules error: operator not supported for strings was created by v.garofalo
Posted 3 years 3 weeks ago #28719
I've got a big problem with template modules. When I try to edit some modules it says: [] operator not supported for strings.
This happens only with some types of modules, like the slideshow, the mosaic and the grids. Help me please, I need a solution.
Regards.
Regards.
by v.garofalo
- Thank you received: 1711
Replied by joomlaplates on topic Modules error: operator not supported for strings
Posted 3 years 3 weeks ago #28722
please install the roksprocket module again.
BTW which php version is installed?
- v.garofalo
Replied by v.garofalo on topic Modules error: operator not supported for strings
Posted 3 years 3 weeks ago #28725
Hi, how can I install the roksprocket module? If it is a file to put into a directory, can you please send me the file and give me instructions?
The php version is the 7.2.
Regards
Regards
by v.garofalo
- v.garofalo
Posted 3 years 3 weeks ago #28728
I updated roksprocket, it works now.
To download it go to this link:
www.joomlaplates.com/index.php/support/d...how-with-roksprocket
Thanks for the support.
by v.garofalo
- v.garofalo
Replied by v.garofalo on topic [SOLVED] Modules error: operator not supported for strings
Posted 3 years 3 weeks ago #28729
by v.garofalo
