[SOLVED] double scroll bar when using any lightbox
I have a little problem.
Hi and thank you in advance about the help.
I tried 3 different lightbox to open an article page, but I can see one more scroll bar
please see as attachment.
Page link: www.noh-art.com/little-shop-of-art.html
the problem comes out when I click on the Enquire button.
The problem is here:
www.noh-art.com/templates/jp-time/styles/Black/css/theme.css
L. 10341
How do I have to change removeing completley the scroll bar?
And how I have to change as override?
To avoid come back the error after upgrade the template.
Thank you for your help.
Tony
L. 10341
html {
overflow-y: scroll;
Tony
Last Edit:3 years 1 month ago
by nohart
Last edit: 3 years 1 month ago by nohart.
- Thank you received: 1713
Replied by joomlaplates on topic double scroll bar when using any lightbox
Posted 3 years 1 month ago #28853
Hello, I cant see any double scroll.
Did you fixed it?
Did you fixed it?
Replied by nohart on topic double scroll bar when using any lightbox
Posted 3 years 1 month ago #28861
I modified directly the css under style folder (becouse I created a custom CSS called black and modified that)
Thank you
Thank you
by nohart
Replied by joomlaplates on topic [SOLVED] double scroll bar when using any lightbox
Posted 3 years 1 month ago #28866
