TOPIC: [SOLVED] QuickStart does not appear to install correctly
QuickStart does not appear to install correctly 1 year 10 months ago #1
  • abasel
  • abasel's Avatar
I have installed the QuickStart package but all that it produces is a standard Joomla install without the Ultimate template, extensions or any demo data. Is this correct?
QuickStart does not appear to install correctly 1 year 10 months ago #2
  • abasel
  • abasel's Avatar
Just to make sure that I have done this correctly (as per https://www.joomlaplates.com/support/documentation/install-demo-content), I extracted the "quickstart" package into an empy domain, created the database and then installed by browsing the domain. The last step I did choose default English Sample data. The install completed but it is simply a joomla install with no template or sample data.
QuickStart does not appear to install correctly 1 year 10 months ago #3
We have tested the Ultimate package and it works,
please check you made evrythinbg right.
Otherwise we can install the quickstart package for you.
www.joomlaplates.com/installation-form
QuickStart does not appear to install correctly 1 year 10 months ago #4
  • abasel
  • abasel's Avatar
I have installed hundreds of templates and so should not need a service. From what I have seen, I have followed you documentation.. Before I am forced to use your install service could you please take a look at the following to see what I am missing out?
Screen-cast
I have followed www.astemplates.com/joomla-template-documentation/435-002084 but as you will see the site is not setup as per the Demo site.
QuickStart does not appear to install correctly 1 year 10 months ago #5
  • abasel
  • abasel's Avatar
I have just notice something else. I purchased the Ultimate template but looking at my downloads it says "BiZ - Single Joomla Template" which also does not seem correct.
QuickStart does not appear to install correctly 1 year 10 months ago #6
  • abasel
  • abasel's Avatar
I feel foolish. It appears that I accidentally purchased the wrong template. This has now been corrected and the Ultimate install works just perfectly. Thanks for your patience.
[SOLVED] QuickStart does not appear to install correctly 1 year 10 months ago #7
  • abasel
  • abasel's Avatar
