TOPIC: [SOLVED] Content Appearing in Breadcrumbs
Content Appearing in Breadcrumbs 1 year 4 weeks ago #1
  • tmichel
  • tmichel's Avatar
See:
I don't want Joomla content to appear in Breadcrumbs, but rather where it should appear between main-top and main-bottom, but I don't seem to be able to figure out where to set this.
Content Appearing in Breadcrumbs 1 year 4 weeks ago #2
the word "home" is not a breadcrumb. its based on the menu item configuration > Page Title
www.joomlaplates.com/support/documentati...hange-the-page-title
BTW I cant see any breadcrumb module on your site. The breadcrumbs are always above the Joomla system output.
Content Appearing in Breadcrumbs 1 year 4 weeks ago #3
  • tmichel
  • tmichel's Avatar
Content Appearing in Breadcrumbs 1 year 4 weeks ago #4
  • tmichel
  • tmichel's Avatar
I don't know how this happened, but it prevents front end editing. If this were a standard Joomla template and not a WARP template, I would assume that there was a missing closing bracket in the template index.php file, but this isn't a standard Joomla template so I need some help in understanding how it is that content, or the Joomla Component, came to be displayed in the Breadcrumbs position; it should be in Joomla Component position. between Main Top and Main Bottom.
Content Appearing in Breadcrumbs 1 year 4 weeks ago #5
If you dont like the breadcrumbs module, you can disbale the module on the home page.
Content Appearing in Breadcrumbs 1 year 4 weeks ago #6
  • tmichel
  • tmichel's Avatar
If I disable Bread Crumbs, the Joomla Component is still displayed in Breadcrumbs. If I need to edit the PHP just point me to the right file and I will do that. I need the Joomla Component to be displayed independent of module position, in fact in the Joomla Component position. When I write my own templates I select where in the page I want the Joomla component to appear. This is my first time using the Warp engine, and I am pretty impressed except for this one little wrinkle. Really allows us to organize the page styles in a structured way
The Joomla Component shouldn't be displayed in bread crumbs, I must have screwed something up when initially installing the template. I need to fix this now, any ideas??
I have a "Photos" page where I installed my own component that doesn't display the Joomla component and the breadcrumbs works properly. this is how I want all pages to look. Yes I did this before I realized that the Wrap engine allows us to create styles where I can select to not display the Joomla Content. But I have already used this method before realizing that.
Content Appearing in Breadcrumbs 1 year 4 weeks ago #7
you did nothing wrong!
The breadcrumbs is a module which can be disabeld.
And this one is the page title and not breadcrumbs
Content Appearing in Breadcrumbs 1 year 3 weeks ago #8
  • tmichel
  • tmichel's Avatar
Thank you, I finally looked at the code and you were right, I was doing nothing wrong. Installing my blank component is what threw me off, because it only had modules positions and no component which made the page look different. I kind of like the breadcrumbs to span the whole page, but it looks good like it is now, so I won't complain.
All is well now and everything looks beautiful. Go WARP.
[SOLVED] Content Appearing in Breadcrumbs 1 year 3 weeks ago #9
