TOPIC: Responsive problem
Responsive problem 5 years 1 month ago #1
  • opitzlein
  • opitzlein's Avatar
Hello!
I have a proplem with responsive.
in the normal Desktop view, everything is ok (normal-ok.jpg)
But in responsive the list goes over the picture. (responsive.jpg)
i send you the link www.xundheitszentrum.at/xund/index.php/a...inmedizin/pachernegg
Can you help me!
Thanks
Jörg
Responsive problem 5 years 1 month ago #2
Hi there, it depends on your source code.
Dont use a width of 40% for the div and dont use image size in pixel if you want to have a responsive layout.
You dont need an extra "DIV" for the image. Just add a style with float left for the image.
Use a simple Code like this
<img style="float:left; margin-right:1%" src=".png" alt="?" border="0" align="left" width="?" height="?" />
<ul>
<li></li>
<li></li>
</ul>
Responsive problem 5 years 1 month ago #3
  • opitzlein
Hi!
You mean:
And the by the List no DIV float:right;??
<ul>
<li></li>
<li></li>
</ul>
