TOPIC: [SOLVED] Setting background
Setting background 5 years 1 month ago #1
  • standib
  • standib's Avatar
I am in the process of customizing the Universal Template. I see in the profiles options / background, the choice of 'custom' although I can't find instructions on how to use that option.
Can you help?
Regards
Bob
Setting background 5 years 1 month ago #2
Hi there, if you want to have a custom background you have to edit this file:
...\templates\jp-universal\css\background\custom.css
The following user(s) said Thank You: standib
[SOLVED] Setting background 5 years 1 month ago #3
  • standib
  • standib's Avatar
