TOPIC: warp upgrade
warp upgrade 4 years 1 month ago #1
  • konradwb@gmail.com
  • konradwb@gmail.com's Avatar
I also have the problem that my styles do not save. My WARP version is 6.4.8
Please help.
Thank, konrad
warp upgrade 4 years 1 month ago #2
What do you mean exactly with "do not save".
Screenshot please!
warp upgrade 4 years 1 month ago #3
  • Azurit
  • Azurit's Avatar
I have the same problem after upgrade Warp Framework 7.3.31.
Local installation Joomla 3.6.5, Template Qbar
After Upgrading The customizer isn`t working anymore.
Error see attached file.
Thanks for helping
warp upgrade 4 years 1 month ago #4
Sorry. If I make a new profile and SAVE it simply is not there.
warp upgrade 4 years 1 month ago #5
  • Azurit
  • Azurit's Avatar
I found that when I select the original Qbar template style, the customizer is working.
After installation of the template I copied the original one, to not destroy it while customizing.
But all my customizing is in the copied version and of course I need this version.
What can I do?
Thanks a lot
By the way it`s a great template
warp upgrade 4 years 1 month ago #6
Hi there, please take in your mind:
Warp 6 can not be updated to Warp 7.
1.) Gusto = Warp7 with Customizer
2.) Universal = Warp 6 without Customizer
warp upgrade 4 years 1 month ago #7
  • Azurit
  • Azurit's Avatar
Qbar came with Warp Framework 7.3.27 .
As you suggested in another thread I upgraded to Warp Framework 7.3.31 to fix the problem with the fonts.
Since the upgrade the customizer isn`t working anymore.
warp upgrade 4 years 1 month ago #8
Hi, please see the screen shots.
I select a font>Then i SAVE>then the font changes back? What's going on? I cannot set any changes?
I do not find this:
warp upgrade 4 years 1 month ago #9
please clean the Browser and Joomla cache too!
warp upgrade 4 years 1 month ago #10
  • Azurit
  • Azurit's Avatar
I cleaned the Browser and the cache. The customizer isn`t working anymore.
Please help, my production time is running and I can`t do anything.
Since the update there is a new index.php in the root of joomla.
Maybe that this causes the problem?
warp upgrade 4 years 1 month ago #11
New index.php on Joomla root is not from Warp update!!
Please provide me admin access. Use the form to send us the data:
www.joomlaplates.com/contact-us
warp upgrade 4 years 1 month ago #12
This is getting strange. You help everyone except me? And I started the ticket.
This page does not allow me to save! My deadline is here already.
warp upgrade 4 years 1 month ago #13
Please help - my customising does NOT save!
warp upgrade 4 years 1 month ago #14
As I told you above, we need admin access:
support@joomlaplates.com
warp upgrade 4 years 1 month ago #15
Thanks. I did so.
warp upgrade 4 years 1 month ago #16
  • Azurit
  • Azurit's Avatar
It is a local installation with Xampp, so I can`t provide you admin access.
warp upgrade 4 years 1 month ago #17
Then you should try to install the theme again!
Download the newest version and install it!
warp upgrade 4 years 1 month ago #18
  • Azurit
  • Azurit's Avatar
Thanks, I will try.
