TOPIC: Top-a
Top-a 1 year 6 months ago #1
  • Village9991
  • Village9991's Avatar
i've got a question: if i publish n modules into the top-a position, if there a setting to say to the template to show them in max 4 per row? Same question for the top-b-c-d positions. I've tried to put 6 modules into the top-a and all stay on the same row. thanks for any help.
Top-a 1 year 6 months ago #2
You can change the row in the template options > Module
Top-a 1 year 6 months ago #3
  • Village9991
thanks for the reply. I sed the top-a as parallel but if i publish in there more the 4 module they where published all inline. I would like to know if there is a way that from the 5th module in the same position it could be visible on the next line (without using the top-b). www.sebg.it/bg/index.php/edilforum
Top-a 1 year 6 months ago #4
No thats not possible.
The following user(s) said Thank You: Village9991
