TOPIC: [SOLVED] Sidebar menu animation
Sidebar menu animation 1 year 5 months ago #1
  • Holzbein
  • Holzbein's Avatar
In the Template demo is a nice animated sidebar menu. If I try to implement the menu in my sidebar is there no animation. I use the same menu that is placed in the head of my webside and it works fine there.
What do I wrong?
neu.hs-feinblechbau.de
Regards
Sidebar menu animation 1 year 5 months ago #2
the animation is only available if the main menu item is a separator and not a link to a menu item.
Sidebar menu animation 1 year 5 months ago #3
  • Holzbein
  • Holzbein's Avatar
Thank you for your qick reply. I'm afraid I'm not realy sure what you mean. I must not use the navigation module?
regards
Sidebar menu animation 1 year 5 months ago #4
  • Holzbein
  • Holzbein's Avatar
that is the only point that i can find in the documentation:
There are three different menu styles, the Navbar and its mega dropdown as a main menu, the Navs with the accordion effect in sidebars and the Subnavs in the toolbar or footer. Warp automatically styles the menu according to its module position.
I think you can save a lot of time with a proper documentation.
Regards
Sidebar menu animation 1 year 5 months ago #5
I said please use for the top level menu item a separator. > See image below
If the top level is a link, the link is going to an article and cant open the accordion.
Sidebar menu animation 1 year 5 months ago #6
  • Holzbein
  • Holzbein's Avatar
thanks a lot, it works. But it's really hard to find that out by yourself.
Regards
[SOLVED] Sidebar menu animation 1 year 5 months ago #7
