TOPIC: lightbox für xtra
lightbox für xtra 4 years 3 weeks ago #1
  • gf@mso365.cloud
  • gf@mso365.cloud's Avatar
Hi, I'd like to use lightboxes for showing articles. Unfortunatly I did not find any hint how I can do this in Xtra template. Thanks for any hint in advance.
lightbox für xtra 4 years 3 weeks ago #2
if you want to open an image or a Joomla article please use the lightbox which is included:
More inforamtion here:
getuikit.com/v2/docs/lightbox.html
<a data-uk-lightbox="{group:'my-group'}" data-lightbox-type="iframe" href="index.php?id=5?&tmpl=component">Click here</a>
id57 = Your Joomla article ID
tmpl=component = Article only without Template
The following user(s) said Thank You: gf@mso365.cloud
lightbox für xtra 4 years 3 weeks ago #3
  • gf@mso365.cloud
I tried that and i does not work unfortunatly.
www.xlsx.at/
please visit my site an have a klick on "Noch mehr Referenzen" in the TOPC Area.
This will Show the Article as a blanc page but not in a Lightbox as intended.
Did I miss to install something?
Regards
Lars
lightbox für xtra 4 years 3 weeks ago #4
Hi again, I have visited your site and found the issue.
Your template is a lil bit older, the new version is 1.0.006 and here is the lightbox included.
Anyway you can insert the light box component in this way:
Add this code below to your file > layouts/theme.config.php ( line 124)
$this['asset']->addFile('js', 'warp:vendor/uikit/js/components/lightbox.js');
lightbox für xtra 4 years 3 weeks ago #5
  • gf@mso365.cloud
Sorry, that didnt work either.
Name Version
jp-xtra 1.0.003
Warp Framework 7.3.1
I added those two lines to my config file:
$this['asset']->addFile('js', 'warp:vendor/uikit/js/components/tooltip.js');
lightbox für xtra 4 years 3 weeks ago #6
I have checked the code and maybe depends on your installed extensions > widgetkit or slitslider.
Please disable the lightbox frm Widgetkit, see image below
2 Lightbox Scripts may have a conflict!
lightbox für xtra 4 years 3 weeks ago #7
  • gf@mso365.cloud
Thanks for your quick replies and your tremendous Support.
I disabled the widget kit lightbox and this had no Effekt.
lightbox für xtra 4 years 3 weeks ago #8
Yes, please try to disable the slitslider, maybe here is the script conflict.
Anyway we have replaced the slitslider with roksprocket slideshow, because its better for mobile devices.
demo.joomlaplates.com/jp_xtra/
lightbox für xtra 4 years 3 weeks ago #9
  • gf@mso365.cloud
OK.. so now I am confused... I disabled SlitSlider ... Nothing changed.
Then I enabled the Widget Kid Lightbox again ... Nothing changed
and now i am completly confused... should i download the rocksprocket komponent?
lightbox für xtra 4 years 3 weeks ago #10
Please check if your files exists in:
- warp:vendor/uikit/js/components/tooltip.js
- warp:vendor/uikit/js/components/lightbox.js
if not, please update the Warp
lightbox für xtra 4 years 2 weeks ago #11
  • gf@mso365.cloud
That worked. After having updated the Framework now my SlitSlider works fine and the Pop up works aswell. Good work. Thumbs up!
