[SOLVED] Footer Menu disapears on every position on Tablet
  • Milian
[SOLVED] Footer Menu disapears on every position on Tablet was created by Milian
Posted 2 years 11 months ago #33743
I have a strange issue.
My Module-Menu disapears on every position on a Tablet.
I have disabled none of the positions in the Device Visibility.
What more can I do.
For a short page where you see the footer .See:
musora.nl/ja40/linken
Also got a white empty rectangle.
What can it be?
See the attachment.
Regards,
Milian
by Milian
Replied by joomlaplates on topic [SOLVED] Footer Menu disapears on every position on Tablet
Posted 2 years 11 months ago #33744
Hello, it is maybe a menu setting because you installed the Jux megamenu.
But we do not support this menu, therefore you have to find the issue by yourself
  • Milian
Replied by Milian on topic [SOLVED] Footer Menu disapears on every position on Tablet
Posted 2 years 11 months ago #33745
Yes I understand that.
But the Jux megamenu was working fine in another template.
Therefore my thoughts where this must be a template issue.
Regards,
Milian
by Milian
Posted 2 years 11 months ago #33746
Joomlaplates.com cannot guarantee the templates will function with all 3rd party components as there is currently no certification process for such component
Posted 2 years 11 months ago #33747
Das Jux Menu wird ab einer Größe von 768px ausgeblendet ect. siehe Bild
Wie gesagt können wir hierzu keine Lösung anbieten
Attachment jux.jpg not found
Last Edit:2 years 11 months ago by joomlaplates
Last edit: 2 years 11 months ago by joomlaplates.
  • Milian
Posted 2 years 11 months ago #33748
Aha, thanks for your answer.
I think I can do now something in the .(custom).css.
Regards,
Milian
by Milian
