TOPIC: [SOLVED] Modules Not Appearing in WARP
Modules Not Appearing in WARP 2 years 5 months ago #1
  • horric29
  • horric29's Avatar
I've setup the grill template with Joomla version 3.6.2. The modules arn't all showing up in module manager. All I'm seeing is one for bottom-d so I'm not able to change settings for logo, main menu, etc. So I want to center logo I'm going to have to do it through module manager rather than WARP. Is there anything I can do to get the other modules listed here? Any ideas?
Modules Not Appearing in WARP 2 years 5 months ago #2
in template options > modules
are only published modules which have a setup for "icons", "mobile" and so on.
Please read the detailed instructions at:
demo.joomlaplates.com/jp_grill/docs/
>> Logo Setup
Modules Not Appearing in WARP 2 years 5 months ago #3
  • horric29
  • horric29's Avatar
Yep, got that figured out, just didn't get back here fast enough to delete my post... One other question for you... I selected border under modules for a few of the sidebar modules on mrqsskate.com but, they are really really faint. Is there somewhere in configurator to make the boxes darker? I gave it a shot and couldn't find the right setting... I don't want to change the background, just the darkness of the border... Thanks for the quick reply! Amazing template also, I was able to get quite a bit of work done in one day!
[SOLVED] Modules Not Appearing in WARP 2 years 5 months ago #4
  • horric29
  • horric29's Avatar
Not solved one more question...
[SOLVED] Modules Not Appearing in WARP 2 years 5 months ago #5
Add this code to your css/custom.css and change the color code
.uk-panel-border {
border: 1px solid #ededed;
