TOPIC: [SOLVED] background-size cover doesn't work
background-size cover doesn't work 4 years 9 months ago #1
  • mlai
  • mlai's Avatar
It seems that the slitslider module which uses the background-size for the images doesn't work, my images are not reiszed while I'm testing different screen size. It just does the same as if there was no background-size property. (see attached files)
Is there a solution to this problem ?
Thank you for your help
background-size cover doesn't work 4 years 9 months ago #2
I have send you an email with the new slitslider, please install it and try out if it works.
[SOLVED] background-size cover doesn't work 4 years 9 months ago #3
  • mlai
  • mlai's Avatar
background-size cover doesn't work 4 years 9 months ago #4
  • mlai
  • mlai's Avatar
Great it's now working perfectly :)
Thank's a lot
background-size cover doesn't work 4 years 9 months ago #5
  • soundofnumbers
  • soundofnumbers's Avatar
May I also have that new SlitSlider?
I updated the PHP version of my server and SlitSlider is not FullSize anymore...
Thank you in advance.
