[SOLVED] How to change overall background color
- Camphausen
How to change overall background color was created by Camphausen
Posted 10 years 7 months ago #12027
please advise how to change the overall background color (not just background image) including the space between the modules.
ckcmed.com.au/mm
Thanks
Christoph
ckcmed.com.au/mm
Thanks
Christoph
by Camphausen
Replied by joomlaplates on topic How to change overall background color
Posted 10 years 7 months ago #12030
there are 2 ways to setup the background color:
1.) Customizer > background, see image below
2.) Add the color code to your css/custom.css
www.joomlaplates.com/template-customizing#jp-right{background:#ff0000}
Attachment bg-2.jpg not found
- Camphausen
Replied by Camphausen on topic How to change overall background color
Posted 10 years 7 months ago #12042
Thanks for the quick reply.
I changed the general background color to something ridiculous: #E41B77. Subsequently, this color only shows up in the login dialog and on the page "Lehrangebot" in the dropdown box for the number of entries. I was expecting to have all background changed!?
In addition, I tried to find css/custom.css, however, can't find it. Do I need to create it?
Thanks again for your help
Christoph
Christoph
by Camphausen
Posted 10 years 7 months ago #12052
Yes, create a file css/custom.css and add this code to change the background color
Replied by Teddy on topic How to change overall background color
Posted 10 years 6 months ago #12898
I have the same problem. I want define a style with a black background used only on one subpage. Where I have to add the custom.css? In the style subfolder? What is the correct content of this css?
Thanks
Teddy
Thanks
Teddy
by Teddy
Posted 10 years 6 months ago #12900
Ok, in the meantime I found something ...
The main background is located in the template joomlaplates.css and has to be copied into the style custom.css:
Also this one from the style theme.css:
I think the rest I will also find in the joomplaplates.css.
.uk-container {
background:#000
html {
background: #000000;
by Teddy
