Background video with navbar and differnt style IE
Background video with navbar and differnt style IE was created by tkaufmann
Posted 9 years 9 months ago #16140
i bought the Fenya template for my joomla and found out that the look in Internet Explorer and also in Edge is differnt to Firefox. In Firefox the Background video fits the header Background. But in IE and Edge you first see the Navbar from the Video and the Video does not fit the Header Background. I also ckecked the Demo on Joomlaplates with the same result. Two files attached.
Is there a possibility to get the same look in IE/Edge as in Firefox?
Replied by joomlaplates on topic Background video with navbar and differnt style IE
Posted 9 years 9 months ago #16142
Depends on Microsoft, they dont want to support the CSS3 property > object-fit
developer.microsoft.com/en-us/microsoft-...form/issues/7231986/
Attachment edge.jpg not found
Last Edit:9 years 9 months ago by joomlaplates
Last edit: 9 years 9 months ago by joomlaplates.
The following user(s) said Thank You: tkaufmann
Replied by tkaufmann on topic Background video with navbar and differnt style IE
Posted 9 years 7 months ago #16609
Hello again,
is it possible to check if the browser is edge/iexplorer then only show image as Background else show Video?
Because i want to show the Video where it is possible without navbar and also give the Site a nice look if the visitors are using iexplorer or edge.
Best Regards
Posted 9 years 7 months ago #16611
You can disable the video and show only the image.
Add this code to your css/custom.css
_:-ms-lang(x), _:-webkit-full-screen, .video-file { display: none; }
Posted 9 years 7 months ago #16710
thanks for you answer but...
it could be that i am doing something wrong.
If i create the custom.css in ./htdocs/joomla/templates/jp-fenya/css/
there is no change at all. The Video is still showed in Explorer/Edge.
and also if i create the custom.css in
./htdocs/joomla/templates/jp-fenya/styles/green/css (I am using the green Style)
no change.
Am i doing something wrong?
Posted 9 years 7 months ago #16711
Live url please
