Dropdown menus does not appear (anymore)
  • bkoppe
Dropdown menus does not appear (anymore) was created by bkoppe
Posted 9 years 9 months ago #16683
Hello, My jp-world template has functioned perfectly for about several months. I'm now developing on a Login/member area. Since a few days the dropdown menu's doesn't appear anymore under the main menu. Also the litlle arrows have been dissapeared. I'v checked every setting (I think) but nothing works.
When I enter a URL from a sub page than does appear the litlle arrow and the dropdown menu of that part of the menu. When I go to the homepage it has been dissapeared again.
An other issue is, that the button "Mijn NPV" in the main menu not dissapear of the publie (homepage) when I change the access level to "Registrered".
I'm quitte lost, so I someone can help me out here!! Thanks!!
If you need any more data, please let me know.
Main URL: www.npv-pomospost.nl/
Sub-page: www.npv-pomospost.nl/diverse/externe-links
by bkoppe
Replied by joomlaplates on topic Dropdown menus does not appear (anymore)
Posted 9 years 9 months ago #16685
I think its a javascript problem.
Please disable the weather module and try if submenus working again.
  • bkoppe
Replied by bkoppe on topic Dropdown menus does not appear (anymore)
Posted 9 years 9 months ago #16687
Hello, Thanks for your answer. I disabled the weather module but nothinjg changes. This module is there from the beginning and I never had any problems with it.
An other thing is, that when I login as restricted user I land on the page www.npv-pomospost.nl/mijn-npv/welkom-op-mijn-npv . Here, the dropdown menu does work only for this bitton in the main menu. see attachment.
Attachment Mijn_NPV_02.jpg not found
by bkoppe
Posted 9 years 9 months ago #16690
sorry but I have no idea.
But what I see is that there are no submenus in the source code!! See image attached!
Did you set any permission to the submenus?
Attachment submenu-2-3.jpg not found
  • bkoppe
Posted 9 years 9 months ago #16700
The sub-menus under "Mijn NPV" are restricted and just for Members. I've changed them to "public" and nothing changed in the appearence. So I set them to restricted again. The main-menu buttons "Activiteiten", "Fruitrassen", "NPV Info" and "Diverse" are public with submenus and these submenus are all dissapeared as well.
Wenn you login at the bottom of the homepage (Temp account: User: jp, Password: jpjp) you'll see that on the right side of the button "Mijn NPV" now the little arrow appears and the dropdown menus, belonging to that button, appears as well.
Wenn you go directly to one of the subpages f.i. www.npv-pomospost.nl/NPV-info/Bestuur-en-Commissies , you'll also see that on the right side of the button "NPV-info" now the little arrow appears and the dropdown menus, belonging to that button, appears as well. Now it is also possible to swotsch from one sub-page to the other.
I hope this gives you some usefull information to solve this issue. Thansk for your assistance!!
by bkoppe
Posted 9 years 9 months ago #16701
seems there is a problem with your user permission.
When I am was logged in. I could not see any submenus, please check the source code. ( See my image below)
Attachment nav.jpg not found
