Empty space between main-top and bottom
Hello staff, I have a problem about the theme layout. How you can see in the photo attached there is an empty space between the news (main-top) and the sections below (bottom-a). I suppose it depends by the "Hide system output" option, that is checked but nothing changes. With another theme (Expert) I create the same situation and that option in fact removes the space. How could I resolve this issue?
Thank you
Thank you
by assitecno
Replied by joomlaplates on topic Empty space between main-top and bottom
Posted 9 years 4 months ago #17303
Live Url please, we need to analyze the source code!
Replied by assitecno on topic Empty space between main-top and bottom
Posted 9 years 4 months ago #17315
It's a local machine project at this moment that I was building to show at a potential client. Since it seems to be a setting malfunction I hoped that analyzing the source code was unnecessary. I removed the blank space with paint to show the preview to the client, If it becomes a real project I will link to you to be analyzed. Thanks
by assitecno
Posted 9 years 3 months ago #17476
that's the site:
www.ssscongregatio.org
you can join frontend with
user: support
pass: support
please check the empty space I told you above
thanks
user: support
pass: support
thanks
Last Edit:9 years 3 months ago
by assitecno
Last edit: 9 years 3 months ago by assitecno.
Posted 9 years 3 months ago #17481
add this css code to your css/custom.css
hr.style-one {
margin: 0;
The following user(s) said Thank You: assitecno
Posted 9 years 3 months ago #17482
Thank you guy.
I was also trying to set a hover background in submenus (example ABOUT US->Life story) like in the parent menu. I tried with the costumizer but I couldn't find the exact parameter to change. Could you help? Thanks
by assitecno
