[SOLVED] Default color choices ...
Is it possible to change any of the default color schemes to something else? Or, add an additional color scheme?
Last Edit:7 years 9 months ago
by ofisboy
Last edit: 7 years 9 months ago by ofisboy.
The Folio template. I would like to be able to get the color scheme to coordinate with the color of the logo, if possible.
I must be doing something terribly wrong. In addition to the above issue, I created an article page I no longer want but when I try to unpublish it or put it in the trash it brings the whole site down. Once it's unpublished or in the trash I get a 404 - Page not found error on the site. It appears on the front page and now I can't get rid of it. Can you figure out where I might be going wrong?
by ofisboy
1.) Colors can be changed in Customizer
www.joomlaplates.com/support/documentati...the-customizer-warp7
2.) If you disable an article which is set as default in menu item, then the site crashed!! But should be clear!
The Customizer only tells me that "The current theme is not customizable." There are no options to customize in the Folio template. I created a new style and then edited the theme.css. I now have the colors I want but if there's supposed to be a different method of customizing it please let me know. I thought I would have options to select from rather than editing the theme.css directly. Anyway, it's done.
I also couldn't get rid of the page that was causing the site to crash so I wound up re-installing the quickstart. It wasn't tied to any menu so I don't know why I could delete it but that's corrected now, too.
Last Edit:7 years 8 months ago
by ofisboy
Last edit: 7 years 8 months ago by ofisboy.
Please read the troubleshooting guide
yootheme.com/support/question/75099
