[SOLVED] Rocksprocket Mosaic Layout - Spaces are different
Rocksprocket Mosaic Layout - Spaces are different was created by webact
Posted 6 years 6 months ago #26500
hi,
i've got the situation, that the vertical spaces between tiles in a module are to wide. the same module on this site in an other language fits perfect ... can't find a solution, any tips? its the same module used on two sites.
www.my-pv.com/fr/infos/references false
www.my-pv.com/en/info/references right
thanks for suggestions
by webact
Replied by joomlaplates on topic Rocksprocket Mosaic Layout - Spaces are different
Posted 6 years 6 months ago #26515
sorry I dont know.
But I saw that one of site is using a CSS compression and the other site not.
Maybe here is the issue?
Replied by webact on topic Rocksprocket Mosaic Layout - Spaces are different
Posted 6 years 6 months ago #26519
thank you,
i figured out, that on the french page lazyload is einabled, on the other sites it is not active. Dont know how to disable it, or why it is enabled on this one site.
by webact
Posted 6 years 6 months ago #26522
Take a look at > Extensions > Plugins > and search for lazy
Now you can disabe it.
Posted 6 years 6 months ago #26523
thx again, there is no such plugin, no lazy and no smartloading or anything like that.
... hm ...
by webact
Posted 6 years 6 months ago #26524
ok solved, there is a plugin named JCH Optimize, i deactivated it für this page and everything is ok, your hint showed me the right way, thx a lot!!
by webact
