Problem with main menu and logo position
Hello
I have a problem with the main menu of the template host.-When the website opens with Ipad horizontally, the menu drops on the image below. How can I disable it, in order to use only the offacanvas menu?
The second problem is with the logo. I wish it wasn't on mobile, but even if I disable it from the template> forms section, I still see it (and it's too big!) - I attach screenshots
Thanks!
Hello
Thanks!
by griffin
Replied by joomlaplates on topic Problem with main menu and logo position
Posted 4 years 5 months ago #29725
your menu is too long or the fonts are too big.
2 Options:
- Change the font size or padding in menu customizer
- Set the breakpoints, so the offfcanvas comes earlier
2 Options:
The following user(s) said Thank You: griffin
