Missing installation info in package for 3.x
- sfsasupport
- Topic Author
Missing installation info in package for 3.x was created by sfsasupport
Posted 13 years 4 months ago #4068
We just bought and downloaded this file.
Unfortunately nothing says about Joomla version 3.x.
Please, send us this info it is so incredibly important that the installation is done correctly.
Thank you in advance!
Per M. Olsson
SFSA Holding KB Ltd.
www.sfsaflightsupport.aero
Per M. Olsson
by sfsasupport
- sfsasupport
- Topic Author
Replied by sfsasupport on topic Missing installation info in package for 3.x
Posted 13 years 4 months ago #4069
Tried to attach your pdf-instruction but your system did not accept pdf-documents. Why?
It's actually your document.
by sfsasupport
- yvonne mooney
Replied by yvonne mooney on topic Missing installation info in package for 3.x
Posted 13 years 4 months ago #4070
I'm experiencing the same problem with the lofthouse template
by yvonne mooney
Replied by joomlaplates on topic Missing installation info in package for 3.x
Posted 13 years 4 months ago #4071
the demo content installation is the same in Joomla 3.0 as Joomla 2.5.
Quick Installation – SQL Demo Content
1. Install Joomla! on your server
2. Install the Template via Joomla installer
3. Install, only if exists all Module from our extension folder
4. Copy our “image” folder with your FTP programm from demo content directory to your Joomla “ROOT” folder
5. Connect to your Hosting Provider
6. Open the PHPmyAdmin console and switch to your database where Joomla is installed
7. Import the “sql-dump.sql from demo content folder into your database
8. Now go back to your Joomla Admin and login
9. Goto Site Config > Server > Change the database prefix to "jp_"
10. Now youre logged out from system
11. Login with new Username and password. User = admin | Password = password
12. Goto Extensions > Manager > Database > Click fix
Attachment demo-content-installation.gif not found
Last Edit:13 years 4 months ago
Last edit: 13 years 4 months ago by joomlaplates.
