Mobile menu not showing
We followed the guidelines on www.joomlaplates.com/documentation/mobile-menu-configuration/ but still the menu wont show on mobile devices.
Anything we could have missed?
www.mehr-edv.com
www.mehr-edv.com
by gam
Hi there, here is the right description for this template:
1.) Duplicate the Mainmenu module and publish the duplicated menu on module position "off-canvas"
2.) Now you have the same Main Menu module on module position "off-canvas"
NOTE
You can publish any menu on module position "off-canvas" This module position will be shown in responsive vew.
NOTE
Last Edit:12 years 21 hours ago
Last edit: 12 years 21 hours ago by joomlaplates.
Thanks for the quick reply.
The menu is now shoing on mobile devices, but there is no indicator on screen that there is menu just a grey bar on top.
If one taps the left top corner the menu opens, but it does not show any symbol there.
Seems we are using the same color for the our menu background as the \f0c9 symbol.
Is there a way to change this in the less file (or the settings?).
kind regards
kind regards
by gam
Live Url please!
You can change the font color at the customizer section >> off-canvas
Last Edit:11 years 11 months ago
Last edit: 11 years 11 months ago by joomlaplates.
- time4mambo
Excuise me my very bad english, please!
I dublicate the menu we in this thread, but my moblie menu is not viewing.
see my screenshots:
What can I do?
Best regard
Axel
see my screenshots:
Attachment 090.jpg not found
Attachment 089.jpg not found
Attachment 092.jpg not found
Attachment 091.jpg not found
What can I do?
Best regard
Axel
Last Edit:11 years 9 months ago
by time4mambo
Last edit: 11 years 9 months ago by time4mambo.
Hallo Axel,
1.) entfernen sie den Suffix "mobilemenu"
2.) Duplizieren sie das Main menu module
3.) Veröffentlichen sie das duplizierte menu nun auf der position "off-canvas"
Nun sollte das Mobile Menu sichtbar sein
