RokSprocket v2.1.21 - Mosaic - alt-tags
  • andweb
  • Senior Boarder
  • Senior Boarder
  • Thank you received: 1
RokSprocket v2.1.21 - Mosaic - alt-tags was created by andweb
Posted 8 years 11 months ago #17853
I use the template snowflake and the extension RokSprocket, Mosaic. I have unfortunately a problem with the alt-tags.
The images are taken from the corresponding article (introduction picture), where the alternative text was specified.
The override (<?php echo $item->getPrimaryImage()->getAlttext(); ?>) I have adapted:
/templates/corporategames/roksprocket/layouts/mosaic/default/item.php
<?php if ($item->getPrimaryLink()) : ?><a href="<?php echo $item->getPrimaryLink()->getUrl(); ?>"><?php endif; ?> <img src="<?php echo $item->getPrimaryImage()->getSource(); ?>" alt="<?php echo $item->getPrimaryImage()->getAlttext(); ?>" class="sprocket-mosaic-image" /> <span class="sprocket-mosaic-hover"></span> <span class="sprocket-mosaic-shadow"></span> <?php if ($item->getPrimaryLink()) : ?> <span class="sprocket-mosaic-hovercontent"><span>&nbsp;</span></span> <?php endif; ?> <?php if ($item->getPrimaryLink()) : ?> </a> <?php endif; ?> </div> <?php else : ?> <?php if ($item->getPrimaryImage()) :?> <div class="sprocket-mosaic-image-container"> <?php if ($item->getPrimaryLink()) : ?><a href="<?php echo $item->getPrimaryLink()->getUrl(); ?>"><?php endif; ?> <img src="<?php echo $item->getPrimaryImage()->getSource(); ?>" alt="<?php echo $item->getPrimaryImage()->getAlttext(); ?>" class="sprocket-mosaic-image" /> <?php if ($item->getPrimaryLink()) : ?> <span class="sprocket-mosaic-hover"></span> <span class="sprocket-mosaic-shadow"></span> <span class="sprocket-mosaic-hovercontent"><span>&nbsp;</span></span> </a> <?php endif; ?> </div> <?php endif; ?>
However, the alternative text of the article image is not displayed in the source code: www.corporate-games.de
What am I doing wrong? :)
Thx in advance
Uli
Last Edit:8 years 11 months ago by andweb
Last edit: 8 years 11 months ago by andweb.
Replied by joomlaplates on topic RokSprocket v2.1.21 - Mosaic - alt-tags
Posted 8 years 11 months ago #17855
Hi Uli,
please update the roksprocket and then use the following code for the "alt" parameter:
alt="<?php echo $item->getPrimaryImage ()->getAlttext(); ?>"
Last Edit:8 years 11 months ago by joomlaplates
Last edit: 8 years 11 months ago by joomlaplates.
  • andweb
  • Senior Boarder
  • Senior Boarder
Replied by andweb on topic RokSprocket v2.1.21 - Mosaic - alt-tags
Posted 8 years 11 months ago #17857
I am a bit confused :)
I already use the current version (RokSprocket v2.1.21) and the code is already included.
by andweb
Posted 8 years 11 months ago #17858
1.) Clean your Joomla and Browser cache
2.) Insert an alt tag for the Content image > image 1
3.) Check the source code > image 2
Attachment alt2.jpg not found
Attachment alt1.jpg not found
  • andweb
  • Senior Boarder
  • Senior Boarder
Posted 8 years 11 months ago #17861
Hi again,
Unfortunately, all this has brought no success.
Attachment image-alt-tag.JPG not found
Attachment graffiti-code.JPG not found
Uli
by andweb
Posted 8 years 11 months ago #17863
Maybe you are in the wrong file.
Please check it, because there are 2 different styles > gallery and default.
and
/templates/corporategames/roksprocket/layouts/mosaic/gallery/item.php
The following user(s) said Thank You: andweb
